Isolation material @ pipe supports
HRK1
thread378-96214
Thanks for the comments, our refinery was built using nothing under the pipe, then pipes were lifted and round bar was used. I agree that the round bar puts a point stress load on already weakened pipe (due to corrosion); we have also tried FRP pads and of course we didn't do a very good job installing the first few, so inspections will not allow us to use them any more. I will use a teflon liner in this certain case.
Doubtful you need teflon if it is not required for minimizing friction from expansion or contraction.
Only put off until tomorrow what you are willing to die having left undone. - Pablo Picasso
