So, first off fsincox, as I've already said I have a copy of 2768 and back when I had my first run in with it spent a bunch of time studying it thank you very much. As an idea of a standard to suggest what are realistic manufacturing tolerances or similar it arguably has some merit. However, as a complete and comprehensive solution to the never ending problem of most designer not being willing/able to spend enough time & effort to properly tolerance drawings/do so most efficiently I'd say it's a miss.
Say whatever you want about checkers, our place 'saw the light' a couple of years ago and I no longer get that miserable task, except when someones drawings are so bad that even management can't divert the blame. Now I even get to do some project management so I could play the other side of the fence if I really wanted.
I believe there was an ASME equivalent to 2768, which was indeed a din originally. I think it's been brought up before, or maybe I'm imagining it.
I've already said that using 2768 incorrectly is comparable to using the typical inch block tols incorrectly. Though, one might incorrectly think they were doing a better job simply by referencing a 'standard' than relying on some fairly arbitrary numbers on a drawing template or similar.
The first few years of my career were in the UK to iso standards, so any implications of nationalism are questionable.
Finally, the implications that using 2768 is analogous to the whole 'critical dimension' debacle is scary stuff - enough to make me like it even less.
