Iserting Eccel Sheets into a drawing
  • Thread starter Thread starter edl
  • Start date Start date
E
edl
Guest
How can I insert a Excel sheet into a drawing that is not link? Or can I make a table out of a excel sheet?
I found this on the PTC website:
How to import a Microsoft Excel table into a drawing.
Alternate Technique
See Resolution Below.
Resolution
To Place a previously created Microsoft Excel worksheet on a drawing, use #Insert, #Object, #Create new from file and browse to the file name of the worksheet.
The text will display as the color used in the worksheet, so if the text color in Microsoft Excel is black, the text will blend into the background of the drawing. Change the text color either through Microsoft Excel or by modifying the text style through Pro/ENGINEER.
Double clicking on the worksheet while in the drawing will start up Microsoft Excel and changes can be made to the worksheet.
Which Revision of ProE does this work on????
I have tried this in Pro/E 2001 and it works fine.
BUT NOT IN 2000i2!!!!!!!!!!!!!!!!
