The model is by no means robust. I really had not gotten that far. This was really just a starting point. All the curves are sketched curves and the surfaces were created as style surfaces. As far as creating a four sided patch across the three sided patch, this was more of a response to how you could break up the three sided areas into four sided areas.
The first curve was the base circle on the TOP datum plane. The second curve is a spline curve that is attached to the base circle and has a height dimension along with some other dimensioned points. The third curve is attached to the base circle and its center point is attached to the center point of the second curve and is the same as curve two.I offset a datum plane from the TOP datum and created four datum points at the intersections of curves two and three with DTM1 and created a curve on DTM1 through the points using the ellipse option. These curves, so far, areupdating as expected (second picture shows chages in height of curve two and diameter of base circle). Curve five is the same as two and three, however, right now it is not updating with changes made to the height of curve two and the base circle diameter. I offset datum planes from the FRONT and SIDE planes and created points at the intersections of curves two, three,five, and the base circle with the planes DTM3 and DTM4. Curves six and seven were created through the points and seem to be updating (picture three shows how the curves are updating: curve five (red) is not updating). I can make changes to the offset dimensions for DTM1, DTM3, and DTM4 (DTM3 and DTM4 offsets need to be changed together: picture four shows the changes). Five surfaces were created in the style feature (picture five shows the surfaces created).
