shaneelliss
Ok, I am reviewing some calcs for a two story stick framed home with full basement. The concrete foundation wall is stepped down in the rear for a walk-out basement and conventional stick framing is used for the walk out portion.
Should this house be considered a three story home? Typically with only two stories above ground, I would say no, but because the whole rear of the home is stick framed, I would have to say yes. Am I wrong?
Should the rear basement walls that are stick framed be designed to resist shear? I think they should, though no calcs are provided for shear resistance on the lower walls.
Also, the house has in-plane and out-of plane irregularities. If I remember correctly, ASCE7-05 says that the engineer cannot use the simplified seismic method on an irregular structure that is 3 stories. Is this correct?
And one more question. The house has a raised roof portion over a staircase that is separate from the rest of the main roof structure (engineer calls it a turret). The front exterior wall that supports this roof is rounded (maybe 8'-10' diameter) and the back of this raised roof is supported by a wood beam and posts on the interior of the home. I think because the roof is a separate diaphragm that this part of the structure will act somewhat independently from the rest of the home. The engineer shows shear walls on each side of the raised roof and across the rounded front, but nothing on the rear. Two things jump out at me: one is a rounded shear wall (which seems too small of a round to bend OSB around without breaking it), and the other is no shear resistance in the rear. Any ideas on how the shear resistance should be handled? I have told the engineer that I do not like what I see and that I cannot accept a round shear wall but maybe I am being too hard on the guy or otherwise unreasonable. He seems at a loss of what to do. Any thoughts?
Long post, with lots of questions. Any help will be appreciated.
