Is this GD&T correct 1
SiW979
GB
Hi People!
I'm looking at a drawing and am trying to convince myself that I'm reading it wrong, but I can't. It just doesn't make sense to me and everyone I've shown it to so far agrees, but we're not confident enough with our GD&T knowledge to say it's definitely wrong, as it'll be wrong on many drawings, and dates back nearly a quarter of a century, across a number of suppliers, none of which have said, "no, that's rubbish!".
Is it logical to specify a thickness of 3.9/3.8 (so, ± 50 microns) and have a flatness tolerance band on both sides of 250 microns. I suspect that the 250 microns should be 25 microns, but am not 100% confident. I'm thinking that based on the faxt that flatness is measured between two parallel planes, that the parallel frame is not required and I could just get away with the flatness tolerance? and that the drawing is over constrained? Or am I wrong? Also do I need a datum for a flatness tolerance?
Many thanks
Simon
Best regards
Simon NX7.5.4.4 MP8 - TC 8
The document I have is a German company standard (SULZER??) it notes: "Corresponding to ISO1101" at the top of the page and is dated from 1976.
The text part is as follows:
"4.4 If two associated features are identical and there is no reason to give preference to one as a datum feature, then the tolereance is indicated as in figure 19."
Figure 19 is a parallelism callout as shown on your document.
I think it is a interesting and valid concept, myself.
If it’s from 1976, it may be listed in the back of pmarc’s 1983 as “former practice”. I wonder…
pmarc,
The only problem I have with the concept IS any reference to a datum, in the classic sense. A datum is a reference to the "a concept of perfection". I want "imperfect face" to "imperfect face", I see value in that concept, no more constrained conditions needed, just as it sits, just like the old time shop practice.
There is nothing in the back of '83 edition. The document has got no appendices at all.
Unfortunately I do not have a copy of replaced ISO/R 1101-1:1969 to see earlier practices.
Yes, this is what I was talking about in my first post in this thread.
What I like about your document fsincox, is that using capital letter to identify datum feature is not a requirement but rather an option.
The standard sure went a long way since that.
