I had some issues with a pressure switch on the discharge side of a fan the other day. It was cycling often so I removed the switch and replaced it with a freshly calibrated switch. After I removed the switch I tried it on the bench, it worked great! I then hooked a 754 with a pressure module up to the inservice pressure switch by putting a T fitting in the sensing line. I datta logged the switch for 2 days acumulating well ofer 14K points of data. Not once has the switch cycled. The only change made was hooking in the meter. Has anyone come by a situation where increaing volume on the sensing line of a switch had a damping affect on it? Do they make a product like a tubing fitting to dampin a switch?
