I just found this fabulous SS Forum and have browsed around but could not find an answer to my issue mentioned below. If this is more correctly placed in one of the Code Forums, please advise:
We have a couple of weld procedures on 304L and 316L that we apply to AWS, Mil & on rare occasion to ASME projects. I have made the suggestion that if we ever hope to provide welding (GTAW & SMAW) on other 300 and 400 series alloys, we should develop new WPS's because our limited experience with 304L and 316L, which seems to be almost immune to carbide precipitation concerns, may require other post weld heat treatments. While my argument held some attention with the management for about a minute, I was told to answer what qualification tests required by Code or specification would provide proof that we can weld satisfactorily and deliver weldments that will not be vulnerable to intergranular corrosion.
Having gone through AWS D1.6, Mil-Std-278, ASME Sect IX and B31.3, I can't find mention of any test (any required test) that will show that a new procedure is capable of producing sound welds, free of chrome-carbides. I suppose some WPS's are application dependent and customers may dictate some kind of corrosion test.
But to my specific question: What Code required tests will address the potential carbide precipitation concern? Will this be revealed during a tension test, bend test or an impact test?
Thankyou.
Thankyou.
