IS THERE ANY RELATION BETWEEN CYCLE AND ENGIN VALUE
soheil1979
Petroleum
IR
HI
I HAVE A ENGINE THAT HAS PLATE WHICH IS SHOWED RECYCLE PER MINUTE(RPM)AND VALUE OF ENGIN BUT I WAnt to know what is its power
many thanks for your helping
Please tell us the number of RPMs (we say "revolutions per minute") and the VALUE of the Engine.
does "value" mean torque (ft.lbs) ?
Power = Torque X RPM X Constant (to convert to appropriate unit system).
If this is an internal combustion engine, torque will not be a constant value.
Most industrial gas engines have very flat torque curves from 60% to 100% of rated speed, so HP is fairly linear. Thats how we can run speed control on reciprocating compressors coupled to engines.
prost (Structural) 30 Jan 08 11:10
do you have any indication of the physical size , number of cylinders, is it diesel or petrol powered ??
Your question at the moment doesn't make any sense, the power could be anywhere from 1/2 hp to a few thousand hp.
