Related to Your question...?
ASTM F483 STANDARD TEST METHOD FOR TOTAL IMMERSION CORROSION TEST FOR AIRCRAFT MAINTENANCE CHEMICALS
ASTM F502 STANDARD TEST METHOD FOR EFFECTS OF CLEANING AND CHEMICAL MAINTENANCE MATERIALS ON PAINTED AIRCRAFT SURFACES
ASTM F1110 STANDARD TEST METHOD FOR SANDWICH CORROSION TEST
ASTM G1 RECOMMENDED PRACTICE FOR PREPARING, CLEANING, AND EVALUATING CORROSION TEST SPECIMENS
ASTM G50 STANDARD PRACTICE FOR CONDUCTING ATMOSPHERIC CORROSION TESTS ON METALS
ARP1512 CORROSION OF ALUMINUM ALLOYS BY AIRCRAFT MAINTENANCE CHEMICALS SANDWICH TEST
SAE J2635 FILIFORM CORROSION TEST PROCEDURE FOR PAINTED ALUMINUM WHEELS AND PAINTED ALUMINUM WHEEL TRIM
SAE J2721 RECOMMENDED CORROSION TEST METHODS FOR COMMERCIAL VEHICLE COMPONENTS
USAF T.O. 42A1-1-1 EVALUATION AND SERVICE TESTING Of MATERIALS CLEANING, PAINTING, SEALING, PROTECTIVE TREATING, ANTI-CORROSION, INSPECTION MATERIALS AND RELATED ITEMS
