Is there a standard that requires a parts list (or BOM) in a certain section/placemnt of the print?
ingallspw
178
Is there a standard that requires a parts list (or BOM) in a certain section/placement of the print?
Sorry, hit post too soon.
What I mean is does the parts list have to be on the bottom in the middle, left corner, right corner, upper corner, lower corner, etc? If there is such a standard, where would I find this?
Thank you!
If you are in ASME world, you may want to search for ASME Y14.34. In the '96 version of the standard (there is a newer version, issued in 2008) paragraph 5.5 is what you probably need.
Great thank you. I found it.
Where they require it seems to take a ton of paper real estate.
Thanks!
How is placing it above the title block taking up a ton of paper real estate - unless it's a really long parts list?
It's long (and I could be putting in the blank are next to the tile block).
