Emmette Kelly
Agricultural
We have an application where we need to control the movement of an 800 pound piece of steel that rides on a track that can move 15 inches in a straight line, up and down. The structure that it's mounted to tips, and when it does, this 800 pound piece of steel will slam against the stops after moving over that 15 inches on the track. This is obviously an issue. We need to keep that 800 pound piece of steel stationary, until another force acts on it, and causes it to move.
Initially, we had the idea of putting it on gas struts, like the hatchback of a car. The steel would not move until a force limit was hit, and then it would move slowly. The problem is that the pressure where the strut starts to move changes depending on the position of the strut cylinder, and the temperature. They also don't much like outdoor environments. Our product could be used anywhere from frigid cold to summer heat. We thought about springs, but springs have huge differentials in force depending on how much the spring is extended or compressed. In our application, once say 800 pounds of pressure is exceeded, we want the steel to move in a dampened fashion so nothing slams. When the pressure disappears, the steel returns to its resting position.
Does anyone have any thoughts to technologies or solutions that I can give to our engineering guy to see if they might work in this application?
