I'm building a project with a lot of odd shaped components conflicting regular mating options with their natural shapes (round tubes with square laser cut segments etc) and since I'm using the same part files I need to provide for laser cutting (no fillets, chamfers or angled, machine cuts allowed) my assembly falls apart when I'm moving the assembly segment that should move in real life. I know I could build a partial assembly and save it as a single part, but I would prefer to have one assembly created from "real" parts and sub assemblies. I'm on a tight schedule and this is quite frustrating. Most of the connections I can't weld within SW because the fitting isn't perfect enough for the SW but is normal and easy in real life. I already spent way too much time trying to design each part and to position every piece to it's proper position, but it's still way too fragile to make an animation... I'm attaching an image of one part of the assembly to show that the parts I have to use are not really usable with most f the mates... So, I was thinking that maybe the "lock" mate would help once the two parts are properly positioned. As the final result, I have to be able to move the frame section and the front and rear suspension should move within given constraints (I have no problems with those)
