The management of the refinery I work in want a lot of painting done by operators and fitters to improve the look of the place. This painting will not be done with proper surface preparation (cleaning/blasting) nor special paint systems. They will be brush painting a general purpose paint out of a tin over old paint with surface residues and rust. This is on structural steel, motors, guards, pipes etc.
My opinion is that this could cause accelerated corrosion particularly where active rust will get some level of coating over it and then may stay wetter for longer and may tend to generate aggressive corrosion cells. (We have plenty of rain here)
I would value your input on this. If my fears are correct I could do with some reference material to back me up (I have not been able to find anything, I suspect because doing something like this is a bad idea)
