The reason that A:F is so important is that the A and F have different solubility for various elements.
These alloys are designed so that at near 50/50 the aqueous pitting resistance of the two phases will be nearly identical.
But as you get further away one phase or the other becomes more dilute (for example nearly all of the N ends up in the austenite, so the concentration at 50% A vs 75% A will be significantly different).
This leads to one phase having lower pitting resistance and thereby lowering the corrosion resistance of the alloy.
This is why annealing temp is so critical, changing temp changes the A:F ratio.
In a similar way the formation of intermetallics will damage both the mechanical properties (lower toughness) and pitting resistance. Some of these compounds are easily corroded themselves, and in other cases it is a matter of local depletion akin to sensitization. In order to avoid these you have have a good cooling rate from anneal and watch your max service temp.
I should point out that corrosion resistance of a duplex in any environment other than aqueous chloride bearing needs to be tested carefully, this is the service that they were deigned for.
The lean duplex alloys are very easy to process and fairly forgiving.
2205 is not much harder, provided that you have a well balanced chemistry.
The superduplex grades are the graduate level work.
P.E. Metallurgy
