diamondcat
Automotive
When I use the 'Insert Callout' command in a drawing and select a cosmetic thread, I am given a note that read 'M12x1.75 Tapped Hole'. Typically our callout would be 'M12x1.75 TAP THRU, (4) HOLES'. Is there anyway I can set this so our note std is used every time? Also, can I have a second line of text with a variable that is the number of holes? This variable would need to update with the number of holes on the part. I am using 2001+
