I think you need to move all of the views around from sheets to get what you want. So the work flow I use, is create a new sheet. Move all of the views from the last sheet to that new sheet, move all the views from sheet 1 to the next to the last sheet, then move all of the views from the new last sheet to sheet 1. Delete the new sheet that was created. It goes pretty quick if you have everything associative to your views. Do not forget you can also copy and paste the stuff that is text, and table, and most of the other stuff. just a thought.
