Is it possible to animate one dimension in part? 2
IvanNX
267
As showcase I have to present how model is changed when one dimensions is changed. Design is heavy parametric so it is not simple change even if it is driven by one dimension, so to properly present all differences I would like to animate that one dimension. Is that possible and how?
_____________________________
Enjoy your work and have fun!
Create exactly the Expression "FrameNumber"
You can use the following menu:
View / operation / create animation
Then set the option update expression
By this way NX will update FrameNumber during your animation
Didier Psaltopoulos
Thank you it works!
