is it April 1st ?
rb1957
Aerospace
Apr 15, 2005
16,002
from Flight ...
"US Special Operations Command explores amphibious MC-130 transport concept
20 May 2021
The US Special Operations Command is exploring turning its Lockheed Martin MC-130J into an amphibious aircraft by adding two large floats below its hull."
They could call it the albatross, and then see if the name is ironic or not.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
I prefer the 1960's version myself.
Some real "cut and paste" designs here...
maybe the floats detach to deliver a SEAL team ?
making the rear door water tight might e a problem (or an opportunity ?)
Hmmmm… New to me... and I usually stumble-over this stuff.
Any corroborating articles from reputable military aviation sources... or Lockheed???
The 'problem with floats' is that they are primarily intended for relatively calm water... low swells/chop, like lakes, rivers and protected ocean bays.
The seaplane hull-design dreamed-up 'long ago' is MUCH more suitable for open/rough/high-swell sea operations. But overall rough-sea stresses mean a MUCH tougher/stronger/heavier(?) structure.
Regards, Wil Taylor
o Trust - But Verify!
Amphibious MC-130J Transport Is On Special Operations Command's Wishlist ??????????
Regards, Wil Taylor
At least one of those graphics in the "thedrive" link is from about 2000's I think, so one of those ideas that gets rolled out every 20 years or so. Practically the ramp is going to be pretty useless some 20 ft up in the air. How much margin is there in the vertical stab area, as none of those sketches show additional fin area.
The Jap's keep offering pretty good deals on license built US-2, now there is a proper seaplane.
Some years ago Lockheed experimented with an amphibious version of the C130 using a retractable air cushion under the belly. They abandoned the idea after running into directional control problems, particularly in cross wind conditions.
B.E.
With the RCS of a suburban house and ungainly appearance, it would hardly go unnoticed. Given such publicity in advance, I can't imagine it being used in a tactical sense for special operations.
A red herring?
Or filling a capability gap for some edge of the envelope scenario?
de Havilland also experimented with "air cushion" landing, with a -5 Buffalo. The plane was supposed to be able to land on a clearing, with exposed tree stumps.
As someone who's seen (and heard) a seaplane landing (and taking off) ... possibly the least stealthy thing a plane can do ! (and requires an enormous amount of clear water, so very limited operationally).
