My previous work had all been involved with 161 kV and lower so I had little or no knowledge about corona. However we have recently had a substation installed at 345 kV and it sounds like a bacon frying party. Besides the annoyance, is this a problem?
The engineer designed it with a single conductor per phase, approximately 1000 kcmil size, and the corona discharge seems to be significant based upon the snap, crackle sounds. I didn't know enough to make them use two conductors per phase and they apparently didn't know better either.
- The total circuit length is not more than 500 feet so I wouldn't think the losses are any big deal.
- We have tried out our radios below the line and there doesn't appear to be a problem with interference there.
- The worst case current is well below the conductor capacity.
- The plant is in the middle of a corn field and the nearest neighbor can't hear the noise.
So I just want to find out if I should be concerned about a phenomenon which does not appear to be causing any problems. It seems analagous to using a bad paint color choice. It's annoying but no harm done. Comments?
