vmirat
- Apr 4, 2002
- 294
I'm working a project on an existing cmu building. The as-builts say,
#4 reinforcing steel (fill continuous cells w/ grout) 40" o.c.
There is also a cross section of the wall with a note that says,
8" cmu wall (fill continuous gaps w/ grout)
I'm trying to figure out if the wall is fully grouted or if they only grouted where the rebar is located. Based on the notes above, I could read it either way.
Is there a simple way to determine if the wall is fully grouted without having to do a bunch of drilling? I was thinking of using a hammer to see if the sound would be different, like locating studs in a wall.
