Hi guys! Have a project where the butt-weld (well, actually two 45 degree chamfered pieces coming together - think picture frame) used on pretty thin (85 thou thick) aluminum need to be 'invisible'.
The pieces are held together and the customer is okay with a small gap remaining between them - so the weld can only be on one side - hence allowing the other side to remain clean. Are there methods that would reduce/eliminate/allow me to remove after the weld operation the visible HAZ on the opposite side?
Thanks!
Thanks!
