I am evaluating the feasibility of using an inverted siphon to convey sanitary flows below a creek and the hydraulic calculations suggest it will work, although I have pulled out all the stops to get it to work. I'd feel much more comfortable if there was a bit more cushion in the design so I have a question regarding free flow discharge from the siphon.
The siphon will discharge to a pump station wet well and I have considered that the highest "pump on" level (i.e. water surface) in the wet well would need to be at the invert of the siphon discharge. If the pumps were running and pumping out the wet well at the same rate as the influent sewers were entering the wet well, would this not be considered "free flow discharge" even if the water surface elevation was above the invert of the siphon? If so, I could lower the siphon discharge invert and have a more comfortable factor of safety in the design. Any thoughts would be sincerely appreciated.
Thanks, Steve
Thanks, Steve
