Inverse model
  • Thread starter Thread starter Drake_
  • Start date Start date
D
Drake_
Guest
how can create inverse model? Example: I have a model of casting. Water flow throught the casting. I want to see, what is a real shape of that water in thge casting. In other words, I want to see a water in casting instead of casting (model).
Is there any posibility how could I do that?
(using pro/e 5.0)
Edited by: Drake_
PUT THE MODEL INTO ASSEMBLY WITH A SOLID BLOCK THAT ENCOMPASSES IT. then edit, component operation, cut out. you will then have to remove the outer shape of your model.
That works.
Thank you.
