>I was under the impression that when Inventor creates "configurations" it needs to create external files in order to do so.
Someone going from SWX method of Configurations to Inventor iParts and iAssemblies and Design View reps and Position View reps would be frustraited without training. Once you learn the logical flow it seems to represent the real world equivalents pretty good.
In Inventor you create iPart factory - that is a single part from which you create the different configurations each configuration of course being a different file just like each physical part being a different part with a different part number. I can imagine someone who has difficulty setting up a project folder would be totaly confused. Reminds me of the MDT people who can't see that different files for part, assembly and drawing isn't really a nightmare - simply a more representative virtual representation of the physical equivalents the guys out on the shop floor and in the warehouse deal with everyday.
I have seen some examples where SWX type configurations are a better solution. For example a resistor with the legs bent different directions in an assembly. The same part with the same part number in different configurations.
As far as the other mis-info, well enough said...
of course that was taken care of years ago, I'm sure I could find plenty of similar examples
but all I know is I can no longer access
makes me wonder about censorship. Seems like the most active forum for SWX is eng-tips anyhow. But I would like to be able to see an open forum at the company site.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
