Comcokid
- May 23, 2003
- 1,278
Some of the discussion in thread248-169911 is making me ask a question I've always wondered about. I design low power circuits that are tested to intrinsic safety standards. This is not a problem when the circuit requires only a few milliamps at 5 Volts or less.
However, I see advertisements for "Intrinsically safe" radios and and cellular phones.
Example
Given that Cellular GSM transmssion requires a 577 usec (North American GSM) or 1154 usec (European GSM) transmission burst of up to 1.6 to 1.8 amps maximum, that the power amplifier stage must have a stable supply voltage with low impedance (<150 milliohms) to the power source. Or, if the battery has a high effective impedance, you need a large capacitor (>2000 uF) mounted very close to the final Power Amplifer. The way I read the IS specs, you need a large resistor in series with any battery (several ohms rated at tens of watts), and you cannot have a capacitor large enough to store the energy for the TX burst.
How do they possibly get such a device through the IS regulations?
Or are there special IS regulations for communication devices?
Example
