Intralink & rename
  • Thread starter Thread starter nino67
  • Start date Start date
N
nino67
Guest
Hail,
I have the following problem;
I in [intralink] have reappointed a part, the prt has used in a asm, he/she/it/you of the asm has been created the sketch, performing the [check-out] and exploring the [worksapce] with you/he/she/it explore facilities I see the old [name]. The all would not be a problem if you/he/she/it are not used Pro/ Bacth. In fact used Pro/ Bacth for the press in automatic, the sketches that arise from a reappointed part don't come figured in as Pro/ Batch looks for them with the old name. Like resolve the problem?
This message has been translated in automatic, I justify for contingent errors. Thank you
