Finding renamed objects in IntraLink?
  • Thread starter Thread starter ankarl
  • Start date Start date
A
ankarl
Guest
Is there a way to determine if an object in intralink 3.4 has been renamed?
Not to my knowledge. When you rename an object it modifies the metadata for all the iterations of that object. About the only way would be if it was associated to a part number attribute that may not have been modified or possibly only the last iteration had been modified to the new number if Part number and FIle name are the same.
Thanks, confirms what I thought.
There are probably some hidden parameters showing this since the actual filename isnt renamed in the db.
The actual stored file name on the hard drive is a number. The meta data associates this number the the filename. Once the filename is renamed, the old name is gone. There are no hidden parameters holding that original name that I'm aware of.
Actually there is if you are using Windchill. You need to go to the timeline. No other way I know. Not sure about intralink though
