Hello everybody.
This customer has been complaining about fuel filter saturation.
This engine is for interstate bus application here, running on Biodiesel 5.
He states that his filters gets clogged too often.
Fuel sample has been taken from its fuel tanks. The results are attached.
I suspect of contamination of hose degradation (hoses looked from not-so-good quality). But I also suspect from wear metals from the engine.
Fuel tanks are made of stainless steel.
Could you please cast an eye to the attached results and shed some light on it?
What elements do I have to look in the results?
Keep in mind the rubber hoses are suspicious.
My try: ICP plasma can only detect particles up to 8 microns. That could be the reason why even this results show high PQI value, it shows no Iron ("Fe") in the wear analysis. It says "Fe= 0 ppm".
But it shows an elevated Sulphur value "S=60 ppm". Could it be from vulcanized rubber? It is composed of sulphur.
Since the fuel here is around 30 ppm, this value is out of range.
Any help is welcome.
Thank you.
Azraelo
Thank you.
Azraelo
