ldffernandes
I would like to ask for your help in interpreting the true position geometric tolerance of the attached drawing.
I believe it specifies that the axis of the pocket with diameter DIM A should be contained inside a cylinder with diameter 0.3 and whose axis:
- is perpendicular to the face with datum A;
- is coincident with the plane defined by datum B;
but I don't understand what constraints datum C imposes. Can you help me figure it out?
