Wonder if any of the gear experts out there could offer me some advice. I have in internal ring gear module 4 25° pressure angle with 444 teeth and a profile shift of -2.
I want to run a pinion with 37 teeth (12:1).
Now, my initial thoughts were to use a profile shift of +2 on the pinion to keep standard centre distance and pressure angle but looking at my turegear.lsp generated tooth profile that is too much profile shift and results in the involutes actually crossing before the tip of the tooth (reducing the addendum and making a very pointed tooth). So if this is not possible, how do I decide the ‘correct’ amount of profile shift for the pinion?
If someone can recommend a figure and give a brief explanation why this figure was chosen I would be most grateful (I appreciate the technicalities of sliding etc. may be too much to explain in simple terms, in which case I’ll just settle for the figure , thanks).
I think I should be able to work out the correct centre distance for the shifted gears as I think I understand the process of calculating the involute function and working pressure angle to establish the centre distance.
Many thanks.
Many thanks.
