So, our software guy has designed a PWM drive for our new 30kW Buck Regulator Design. Unfortunately, he has chosen an Arm Microcontroller that is powered with 3.3VDC, and the Analog inputs for voltage and current are also limited to 3.3VDC.
My current sensor is a LEM, with a nonimal output of 4V @ 100 Amps. (Hopefully, I won't see more than 60 Amps, but we all know better than to make that assumption.)
How do I safely limit the Analog Input to the microcontroller to 3.3V?
I was thinking of an Op Amp powered with 3.3V, and a Zener diode on the input...would this work?
I am a Pulse Power Engineer, usually dealing with high voltage and high current, so I could use some advice here.
Any comments or suggestions would be greatly appreciated. Thanks!
