Turbinator
Running some calculations, it looks like putting an intercooler after a positive displacement supercharger will result in lower pressure after the blower, all else being equal (vs. non-intercooled).
My reasoning is that the blower alone is what determines the mass air-flow into the engine, and increased air density after the intercooler would result in a greater volume flow before the intercooler, which would reduce the volume ratio before and after the blower, meaning a lower pressure ratio (and lower heat from compression and less parasitic loss, etc).
Am I correct here? I know the intercooler would have no effect on mass air flow if nothing else was changed, but doing some searches I haven't found anyone saying the manifold pressure would be lowered.
