The attached drawing is the portion of a shaft where a combination guide and thrust bearing interfaces. The bearing surface is Babbitt and is oil lubricated.
I am trying to determine where the conflicts, if any, are between the size, circularity and straightness tolerances. The sketch is fuzzy: the tolerance on the 290mm diameter is -0.291mm to -0.323mm, or 0.032mm total on the diameter. This drawing is from an European company and there is no ISO GPS standard referenced, so for discussion, assume Rule #1 is NOT in effect.
Note: Please ignore the problems with the "parallel to A" FCF - a datum feature "A" cannot be parallel to itself. Also I am not concerned with the runout and flatness FCF's - it should be total runout.
Issue 1 - the circularity tolerance of 0.06mm is radial error, so the diameter can vary twice this - 0.12mm - and still meet the form requirement. But this is 4 times the size tolerance of .032mm. From my understanding, even without Rule #1 the form error must be at least half of the size error. Comments please.
Issue 2 - Given the independent and two-dimensional nature of the circularity and straightness tolerance zones, the 290mm diameter could be a conical shape and still meet the form tolerances. But, given the 0.032mm size tolerance, the 0.60 circularity and the much tighter 0.01 straightness tolerance, how do these interact? I suspect a conflict. My understanding: given the (radial) circularity error of 0.06mm, a line on the surface can "jump" 0.06 from one cross section to the next adjacent one. This would allow a surface straightness of 0.06mm, violating the 0.01mm requirement. So ...how does the 0.032mm size tolerance overlay with the two form errors, which appear to conflict each other? Given the surface is a bearing journal, I am thinking of recommending cylindricity as a more appropriate control. Comments please.
