I can't believe there are people on this forum who could think intake design is any less important for forced induction or that any theories are actually significantly different on forced induction.
All engines run on air pressure and pressure differentials. In a sense all motors are boosted. If they didn't have air pressure they wouldn't run. All a turbo or supercharger is doing is multiplying that pressure.
Plenum volume is still important. Runner lengths and diameters will still effect the performance and in very similar ways to NA.
I will agree with gruntgurus last post in that it may not be worth spending a ton of time or money on a street build. In fact for a street build an OEM NA intake will usually be a great choice for a street boosted build. If you are going to take the time and or money to make something then it better be better than stock and that will take some thought and effort.
As for the OP if this motor ever came NA then unless you plan on a massive build pushing the ragged edge it's quite likely the OEM NA manifold would work quite well. Again general manifold function won't change much between NA and boosted.
There are a couple theories among turbo manifold designs. Stock manifolds will usually be tuned for a broad power curve and decent low end. This should also help with your low end spool.
Then you could design and build a mani with tuned induction in mind. A long runner mani with a focus on low end and quick spool. Or you can go shorter with a focus on broad power curve.
Or you can go super short giving up pretty much any effect of resonant tuning and just trying to maximize all out airflow. This will tend to give you more peak RPM power.
Of course these are all very simplified generalizations and there is a lot of finer theory to understand to even start to implement it with some understanding and hope of having the effect you hope for.
Even then there is still some art to it too. Top performance manifolds aren't made off the first design knowing they will work the best. You would make a few designs based off what you think will be best and then you test those designs and then make some variants of the best of those and test and repeat until you are satisfied that you have reached an acceptable level.
As far as general theory, understanding harmonics and sound waves this book is a great start.
