Mar 24, 2025 #1 T thepo Electrical Joined Mar 24, 2025 Messages 2 Is it ok to install Pole Mounted Recloser 24 kV to 13,8 kV distribution system?
Mar 24, 2025 #2 jghrist Electrical Joined Jul 16, 2002 Messages 4,226 Location US The control voltage will be wrong. Depending on the make/model, you may be able to add a VT to correct. Upvote 0 Downvote
Mar 24, 2025 Thread starter #3 T thepo Electrical Joined Mar 24, 2025 Messages 2 jghrist said: The control voltage will be wrong. Depending on the make/model, you may be able to add a VT to correct. Click to expand... Yes need use different VT, how about the overhead Recloser, still works? Upvote 0 Downvote
