I am using the -INSERT command to insert my 3d hardware into my dwg's, but I am having a strange problem. I can insert whatever I want while in 2DWireframe, and then shade the dwg, and they are all visible. But after I shade the dwg I can no longer insert visable 3d solids. They are there and selectable, but you cannot see them. Go back to 2dWireframe and they popup. Here is the string I'm using: -INSERT;*0-80/SCREW/FLAT_HD-100;\1;0
I don't know if I'm doing something wrong or if it's an AutoCad problem. I've tried this on R2000 and R2004(currently using) and both do the same thing.
