I'm trying to insert an Excel spreadsheet into an AutoCAD dwg. (2008 LT)
All I get is a small portion of it. As a matter of fact, if I try to insert it as a WMF, it's the same thing. Is there any way to get the whole spreadsheet to show in the dwg? Thanks.
Highlight what you want, Edit/Copy, go to Autocad drawing Edit/Paste. There are some limits that AutoCAD and Windows imposes so if your spreadsheet is large you will need another method.
I'm not sure about LT...
Highlight the range of the spreadsheet you want to insert > Copy (Ctrl+C).
In Acad... File > Paste special > Paste (or Paste/link) as Autocad Entities. The spreadsheet will come in as a Table.
I have used MSPaint as a work-around. Perform a print screen of the spreadsheet and save to MSPaint. Insert the bitmap file in the drawing. The size of the spreadsheet could be a limitation with this method.
I have used OLE (object linking and embedding) to insert both Excel and Word files. When you edit the spreadsheet, you simply double-click it and Excel will launch. When done, you close the file and it is updated in AutoCAD. By the way, I use Office 2003 and AutoCAD 2004.
I do it the same way as DonPhillips described. Same with editing it later. I haven't had any problems with that process. Also using 2004. We just upgraded to 2007 and I have not tried it yet with the new version.
In excel, do highlight cells of interest>copy. Then paste in acad>right mouse click>resize highlighted area to suit drawing so as to be readable in paper space or model space.
