Entering seismic mass requires inputting all masses in X, Y, and Z directions.
This is tedious and time consuming. What,s worse every time you add or revise a load/mass you have to trace it in your RSA load case and change the mass, again in all three directions. A royal pain in the antebellum. Is there a faster way?
RIsa for example, lets you just designate your seismic mass load cases, and uses those directly.
