input dialog box data usage
  • Thread starter Thread starter -
  • Start date Start date
Guest
I am able to create the input dialog box but cannot seem to extract the data inputs for manipulation. The data is in the form of a 'cell array'.
I would appreciate any help that may be out there.
I want to input some data that has an index of 1 but the data is upto 1000 in length. How do I input it so that I can use each input for computation in matlab before assessing the next input? That is access the inputs one at a time.
you could write a loop with the computation inside and have the matrix number increase on each success change. You could set a counter to match the last matrix number in case you didn't know how many to do.
