info when pattern is flat does not appear 1
stanny123
40
Im using 2005 version, when i flatten a pattern the infomation that tells you the angle,and up or down, does not appear how do i switch it on if possible.
RMB over flat state view...Properties...check box - Display sheet metal bend notes.
Eddy
thank for the reply wot does RMB stand for
I don't think Bend Notes were included in SW2005. I believe they were added in '06 or '07.
