When one clamps an area in the real world it is not perfectly clamped like it is defined in Finite Element Software.
So I tried to test out what the influence of clamping was, in ANSYS. I had an idea to connect every node on the area of the clamping with springs. The springs would have a high K (stiffness). And the other end of the springs would be constrained.
However that seems to be alot of work. I wondered if someone had a better idea. Is it possible to do this automatically in ANSYS.
I would appreciate any advice. Thanks in advance and hope to hear from you.
Kindest regards,
mab
Kindest regards,
mab
