Why isnt there A
I am trying to find the construction material: steel anchor bolt to concrete, concrete anchor bolt adhesive, combustion temperature and found no information.
-I know a guy what coated his job site tool box in expired anchor bolt adhesive on the inside and it was almost impossible to grind through he said.
-what is the best grout/steel apoxy to use for this application?
-Diamond dust could also be applied with the adhesive or put into the material.
If you could imagine the marketability of a impenetrable toolbox and make a patent I would buy one.
(Currently what is the best material I could use to mix with diamond powder with a high flash point with some elasticity) like Hilti hy-150
