Tmoose
- Apr 12, 2003
- 5,636
It seems typical to plug each stub shaft right into the side of the diff and engage the side gears. With an open diff When the wheels go different speeds rounding a turn or playing in the snow the stub shafts run at speeds +/- the ring gear/diff carrier speed. The bearing that supports and centers the highly finished steel stub shaftjournal is just a nicely fitted hole in the iron/steel diff carrier.
Is this how everybody does it? Or are some diffs bushed?
