Given the scarcity of SEAMLESS pipe in 304-304L 16-inch sch.80, the question I have is: IF the longitudinal weld applied at the mill on WELDED pipe is given 100% x-ray inspection successfully, then can the allowable stress on the welded pipe be raised to ASME code value of 18,000 psi as in seamless pipe?
Thanks for your consideration.
