Jul 16, 2008 #1 mgard79 Mechanical Joined Jul 16, 2008 Messages 6 Location US I have a direct drive pulley system that has a relatively large cable size wrt the pulley diameters. Should I take the cable thickness into account in my calculations?
Jul 16, 2008 1 #2 MikeHalloran Mechanical Joined Aug 29, 2003 Messages 14,450 Location US Calculations should always use the pitch line of the cable, wherever it is. E.g. for a cable over a 'flat' pulley or right circular cylinder, the effective radius is the pulley radius plus the cable radius. Mike Halloran Pembroke Pines, FL, USA Upvote 0 Downvote
Aug 26, 2008 #3 chicopee Mechanical Joined Feb 15, 2003 Messages 6,199 Location US In addition to above, make sure that you do not bend the roping system below the minimum bending radius. Upvote 0 Downvote
