greenimi said:
Where we draw the line between first CH picture and the second one - again in the real world - I don't know.
You already started answering your own question.
Could you drive the line between part in OP, and the part with the simple (small) chamfer? Which size chamfer has to be to start worrying?
Standard does not provide exact numbers, ratios, percentages necessary for feature to be considered. Nevertheless, occasionally it provides a clue.
For example in Para. 4.8 abot datum features it says: ..."However, a datum feature should be accessible on the part and of sufficient size to permit its use"
They are steering away from using word "fixture" but they are clearly stating that feature must be big enough to grab on it.
In this line of thought, I believe 30+/-0.3 dimension is a regular feature of size because it is "sufficient".
And little bit of historical perspective.
in 1982 FOS was "set of two plane parallel surfaces"
in 1994 it was "set of two opposed elements or opposed parallel surfaces"
and in 2009 "set of two opposed parallel elements or opposed parallel surfaces"
Nowhere standard says that said "elements" must be exact copies of each other, so I safely assume they may be "sufficient"
You can devise "go-no go" gauge to check size 30 and it will work. When assembled with mating parts it will act as feature of size (imagine it being a spacer of certain size), etc., etc.
The truth is, you cannot always hide behind the standard and avoid making decisions all together.
It is your responsibility to draw the line. If you believe the drawing may be misinterpreted, it is your job to add control (flatness?) to clarify.
In this sense, OP has purely academic interest.
Still, if I remember correctly, when answering "multiple questions" you are supposed to pick the answer as close to what you believe is correct as possible.
Given that part in question is very close to be regular feature of size, I believe the answer will be very close to 0.6, so I chose answer "C"
