In-place mate relationship 1
Urci
hello,
I'm looking to add an In-place mate to a cable which I need to stretch like an elastic to conform to the various stages the objects will be in, The cable wraps around 2 - cylinders, one at each end, the cylinders distance btw each other varies, but the cable connecting the two cylinders does not follow the path of the change. Any ideas will be greatly appreciated.
I'm betting you'll have top post an image, before you get any useful feedback. You're qhestion is a bit too vague for just text.
Windows XP / Microsoft Wireless Optical Mouse 5000 / SolidWorks 2007 SP2.2 / SpaceBall 5000
"Right-click. It's friggin' magic!"... Jack L. Tate
FAQ376 I'm famous.
Have you modelled the cable in-context or as a non-referenced model and then inserted into the assy?
In the assy, if you use a Layout Sketch to create the cable, and also to mate the cylinders, the cable should update when the cylinders are moved.
[cheers]
I modeled the cable in-context, what I have is a crane assembly, the cable attaches the boom straps to the gantry on the body of the crane. I have a set of 6 sheaves at each location, what I did was create 2 sketches, a circular profile (to be the cable) and a path the cable must follow, I then swept the cable profile around the path to create the cable. This method does not work, I'll try it again, thanks guys for your posts.
An Inplace mate can only be given when you start a new part in an assembly. If you have already built the file then you will have to mate it accordingly.
Scott Baugh, CSWP [pc2]
faq731-376
