12VDC circuit. In line blade style fuse holder. Fuse/holder connection is very tight (difficult to remove fuse). 20A fuse.
When examining this system several weeks ago, I noticed that the fuse/holder showed signs of overheating (some plastic & rubber melting) with the link in the fuse intact. I replaced it with a new holder & fuse.
I got a call from the customer. The fuse holder and fuse had burned up and melted. It melted at the fuse holder, not at the wire connections. I can replace it with another, but don't think I will get a different result.
This system is dual power. It runs off 12VDC truck battery/alternator or (via relays) a Meanwell S-320-12 voltage converter (when plugged in). The load is a fan motor.
Any thoughts on what might be causing this & what to do?
My understanding is that typically when a fuse holder melts, but doesn't blow the fuse, it would be because of loose connections. But due to the tight fit & the fact that we've used thousands of these holders in other applications without the converter, I'm thinking it might have something to do with the voltage converter.
