I usually hang around on the structural forums but I hope no one minds me asking for help here. I am looking for a good book on Holley tuning. I have a kit car with a fairly radical SBC engine (250+ degrees duration at 0.050 lift). It runs fine at the track and so so on the street but I think I can do better if I understood exactly how the air bleeds work.
I have already progressively drilled larger and larger holes in the butterflies to get only 0.040" of the transfer slots exposed. It has very low vacuum at idle so I opened up the idle circuits a little. This made the off idle transfer slots rich so I opened up the idle air bleeds a little and drilled and tapped the transfer slot port for a restrictor.
Now idle is fine, off idle is fine, and a fast cruise where the primaries are working is fine. The problem seems to be that I get a lean condition (I use an O2 sensor and a digital VOM) just before the mains start flowing. Do the main air bleeds help control where the primary circuits start to flow?
Can anyone point me to a good book or paper on the subject? I know I should just go to EFI and I have done that on another vehicle but I want to keep this one "old school". Thanks for the help.
